sitting 2 animation
Hello
I've copied all animations files from the complete characters in the avatar folder. However not all animations appear in the resource windows (for instance sitting2). How can I use this animation for an avatars? Is there a list with each avatar's animations? Thanks |
The reason that animation does not show up in the Vizard resources window is that it's not listed in the Complete Characters .cfg files. It look's like it was not intended to be released with the Complete Characters as it does not show up in the description of animations. You can try it out however by adding it to the list of animations in the cfg file for a character you're using.
YES ! it works. thanks. You have to add the animation in the cfg file. cool
speed on animation path | whj | Vizard | 8 | 11-17-2008 07:41 PM |
Animation Tracks.... | k_iwan | Vizard | 2 | 03-26-2007 05:52 PM |
Jumpy animation | Elizabeth S | Vizard | 1 | 11-08-2006 02:11 PM |
animation sequence | pkhoosh | Vizard | 2 | 01-23-2006 08:03 AM |
avatar animation problems | jrodman | Vizard | 1 | 01-18-2006 09:12 AM |
