Old 06-03-2009, 09:04 AM
Vic Vic is offline
Position and Orientation tracking problem
When I ran my Vizard program and tried to move around with the headset, it wasn't picking up the movement (both position and orientation). I went back and checked the PPT program to see whether the cameras were picking up the movement. They were able to pick up the movement. I'm suspecting it has something to do with my code. I was wondering what could be the cause of this and how it could be fixed.
Vic
Old 06-09-2009, 05:13 PM
GiudiceLab GiudiceLab is offline
Vic,
We use position and orientation tracking in our code. We use a function like this:
import viztracker
isense = viz.add('intersense.dls')
vrpn = viz.add('vrpn7.dle')
marker = vrpn.addTracker('PPT0@' + PPT_HOSTNAME,sensor=0)
view = viz.MainView
def checkHead():
ori = isense.get()
pos = marker.getPosition()
view.setEuler(ori[3],ori[4],ori[5])
view.setPosition(pos[0],pos[1],pos[2])
vizact.onupdate(0, checkHead)
But I'm sure there are other ways to accomplish the same thing, like using a timer callback.
We had trouble at first because we hadn't set PPT_HOSTNAME correctly. This should be the name of your PPT computer, which in Win XP you can find under the Properties if you right-click on My Computer.
Hope that it useful to you.
Can you link the position of a tracker to the orientation of an object? michaelrepucci Vizard 1 09-19-2008 10:23 AM
Flock of Birds (Only Position Tracking working? No Orientation?) TheLostBrain Vizard 6 05-10-2008 08:39 AM
tracking with multiple LEDS dan12345 Precision Position Tracker (PPT) 7 04-02-2008 10:44 PM
position tracking with patriot pgagolf Vizard 4 04-19-2007 04:42 AM
tracking using quaternarion data jfreeman Vizard 2 06-01-2005 08:48 AM
