Old 04-02-2009, 02:15 PM
TrashcanPatrol TrashcanPatrol is offline
Two questions (networking)
Hi, I'm creating a Vizard file in which I have two people connect online and are able to chat and view each other's avatars.
I have a few questions about what can be done with networking...
The first question is, is there any way that you are able to have multiple avatars selectable by each of the players?
The second question is, is there any way to have the two players spawn up at different points?
Also, would it be possible to change an avatar's actions to somehow move whenever someone moves? For example, if I am using vcc_male and I press Up to move (I have the vizcam.FlyNavigate on), when I move forward the other person would see my avatar's legs move in the animation set for the avatar. When I stop moving forward, the other person sees my avatar resume the "standing", regular animation. Is that possible?
That's about all I can think of for now... hope they made sense because what I'm trying to say might not have come out right.
Old 04-02-2009, 02:57 PM
One more thing, is there any way I can have the inbox and outbox text use word wrap so it does not go through the screen and become unviewable? I'm basing the model for this file off of the Duck network chat tutorial, if that makes it easier...
Old 04-03-2009, 01:40 PM
If you want the user to choose from one of several avatars once that user chooses their avatar send that data over and then the other user can load the appropriate avatar.
There are probably a few ways to solve your second question. One easy way might be to use a timer and if the avatar has not changed position for a certain length of time change the animation
This will move the text down to the next lext after if has reached 10 characters
if len(draft_text) == 10:
        draft_text += '\n '
Old 05-05-2009, 02:07 PM
        draft_text += '\n '
This does work, but it moves the text down only once- if you type a long message, it will push it down once but the next time you reach the 10th character it lets it go... is there anything I can do to fix that?
Old 05-06-2009, 02:07 PM
This will add a newline for every ten characters you type. Add 11 each time because one is the newline.
if len(draft_text) in (10,21,32):
        draft_text += '\n'
change the draft_text variable to be an empty string
draft_text = ''
when it's created and everything should line up
Old 05-07-2009, 01:46 PM
        draft_text += '\n'
draft_text = ''
That does work, thanks.
Where would I find more information and options about the text like that? I've gone through the Vizard tutorials but I don't seem to remember that at all... and I don't want to have to trouble you guys every time I have a question about it
3 Easy Questions JMOwens Vizard 3 10-03-2007 12:10 PM
networking nickyee Vizard 1 09-18-2006 04:53 PM
General Questions about Vizard: World Viz dav Vizard 5 08-28-2006 03:44 PM
active avatar functions while networking crazyrusso Vizard 1 11-18-2004 01:08 PM
networking hotspur1 Vizard 3 08-25-2003 10:07 AM
