Hello Wizards,
I would like to know how to use viztip module... Thanks !! viz.FOREVER !!! D. |
The viztip module allows you to assign a tooltip attribute to any node object that contains the tooltip text. Then you just need to create an instance of the viztip.ToolTip object and it will automatically display an on-screen tooltip when the mouse is over the node. Here is a small sample script:
import viz viz.go() viz.add('tut_ground.wrl') #Create models with tooltip text ball1 = viz.add('ball.wrl',pos=(-2,1,5)) ball1.tooltip = 'Ball 1' ball2 = viz.add('ball.wrl',pos=(0,1,5)) ball2.tooltip = 'Ball 2' ball3 = viz.add('ball.wrl',pos=(2,1,5)) ball3.tooltip = 'Ball 3' #Create a tool tip object import viztip tip = viztip.ToolTip() |
Thanks a lot !!
D. |
