Old 06-10-2008, 01:39 AM
dan12345 dan12345 is offline
optimizing the loading of .wrl files
Hi
I'm trying to program an enviorment that supports adding multiple
instances of a .wrl image ( around 100-150 , and dynamically, during
the run of the program ).
The problem is that it takes a very long time and disrupts the flow of the program
adding for example 50 such objects using the "node3d.add(nameOfWlr)" takes about 5 seconds - it just seems a bit wasteful, since it is always the same .wrl file, and each time it loads it anew from the file into vizard. Is there any way to optimize this?
thanks
dan
Old 06-10-2008, 10:00 AM
The most optimal change would be to clone the existing model. However, changing the appearance of one object will affect all its clones. If you want to make unique appearance changes to each model, then the second best thing is to make a copy of the existing model. Here is sample code that will add 50 objects of the same file using the clone technique:
for x in range(50):
    model = viz.add('model.wrl',cache=viz.CACHE_CLONE)
Here is similar code that will add 50 objects of the same file using the copy technique:
for x in range(50):
    model = viz.add('model.wrl',cache=viz.CACHE_COPY)
Old 06-10-2008, 11:36 PM
perfect
perfect, thanks
trouble loading vrml files generated by ProE tavaksai Vizard 12 12-09-2008 11:11 AM
Loading .3ds-Files without interrupting Program flow Stefan Vizard 10 06-08-2005 04:44 PM
Error when playing wav files...? vjonshih Vizard 1 05-23-2005 12:21 PM
loading large wav files in vizard tommahhh Vizard 1 05-16-2005 03:23 PM
Including Files that Include Other Files vjosh Vizard 1 09-21-2004 04:44 PM
