Old 06-30-2006, 02:43 AM
giancamati giancamati is offline
flockOfBirds events
Hello everybody,
I found that Vizard is so simple in working with FlockOfBirds trackers. Now I woudl ask you for how can I event mapping generated by the FOB? I followed the example in the manual that manages the FOB to move the head position. I would use it to change a 3D cursor represented by a sphere. Where can I find an example? What is the event releted to the FOB?
I found that I can map viz.TRACKER but I think this is not the right event. Isn't it?
Thank you so much.
Giancarlo
Old 06-30-2006, 08:56 AM
If you want a model, like a sphere, to take on the postion and orientation of a bird, use the <VizNode>.link( sensor ) command.
sensor = viz.add('flockofbirds.dls');
cursor = viz.add( 'ball.wrl' )
cursor.link( sensor )
Old 07-01-2006, 12:18 PM
Talking
Thank you very much your help will be very usefull but I was asking for is if there is any kind of....
viz.callback(????Events FOB???, functionHandler)
related to this device.
Thank you so much
Giancarlo
Old 07-03-2006, 10:35 AM
There is no event functionality for this sensor. As an alternative, set up a timer that monitors the sensor data and calls a function when the data changes to an event worthy state.
