Old 07-11-2021, 10:24 PM
turinlife turinlife is offline
Registered User
Smile Create Two sequential tasks for images in Vizard
I'm new in Vizard. I'm trying to create a simple code to perform two tasks sequentially for a specific time set:
A black image for 0.8 seconds
A sequence of images (from a folder) taken randomly, for 1.5 seconds. I can perform these task separately, but I can't merge together. Suggestions are very appreciated, thank you
import vizinfo
import random
viz.setMultiSample(4)
viz.fov(60)
vizinfo.InfoPanel()
viz.clearcolor(viz.BLACK)
FRAME_RATE  = 0.667       # in Hertz
r = list(range(7))
random.shuffle(r)
movieImages = viz.cycle( [ viz.addTexture('sequence_IMG/img%d.jpg' % i) for i in r ] )
screen = viz.addTexQuad()
screen.setPosition([0, 1.82, 1.5])
screen.setScale([4.0/3, 1, 1])
def executeExperiment():
    for trialNumber in range(3):
        yield Dark() #wait for doTrial to finish
        yield vizact.ontimer(1.0/FRAME_RATE, NextMovieFrame)
        print('Trial Done: ', trialNumber)
    print('done with experiment')
#Setup timer to swap texture at specified frame rate
def NextMovieFrame():
    screen.texture(movieImages.next())
def Dark():
    yield viztask.waitTime(1) #wait for 1 second
viztask.schedule(executeExperiment())
Old 07-12-2021, 06:05 AM
Use viztask.waitTime instead of vizact.ontimer to wait inside of a task function. It seems like you can place the sequential actions in a single task function:
blankTexture = viz.addBlankTexture(size=(100,100))
        # Show blank texture for one second
        screen.texture(blankTexture)
        # Show movie texture for 1.5 seconds
        yield viztask.waitTime(1.5)
Old 07-27-2021, 12:00 PM
Registered User
Display random images from a folder
Thank you so much!
It is also possible to display the image from a folder randomly without rename all the images in the folder?
an alternative solution for this 3 lines
r = list(range(7))
random.shuffle(r)
images, tasks, vizard 7
Vizard Tip of the Month: Use Tasks to Simplify your Code Gladsomebeast Vizard 5 05-02-2008 04:30 PM
