Old 08-26-2020, 01:52 PM
wbs wbs is offline
ground overlap
Dear all,
I import 3d buildings from SketchUp to vizard, the ground is overlapped. But if i delete the ground = viz.addchild code, it's black and can not show the roads, grass in the SketchUp. How can I solve this problem? thanks.
import vizcam
import webbrowser
viz.setMultiSample(4)
viz.fov(60)
strijp=viz.addChild('srtijp-s building.osgb')
viz.MainView.move([0,100,-3])
viz.collision(viz.ON)
keyCam = vizcam.KeyboardCamera()
gound=viz.addChild('ground.osgb')
ground.collidePlane()
text=viz.addText3D('strijp-s',pos=[-10,5,-6])
def pickobject():
obj=viz.pick()
if obj==text:
webbrowser.open('file:///C:/Netherlands/system%20create/Website%20-wang/index.html')
vizact.onmousedown(viz.MOUSEBUTTON_LEFT,pickobject )
mySound=viz.addAudio('introduction of strijp-s.mp3')
vizact.onkeydown('p',mySound.play)
vizact.onkeydown('o',mySound.stop)
Old 08-27-2020, 01:07 AM
First make sure that the SketchUp model shows up correctly in Inspector. If not, maybe there are some export settings that can be changed. See the SketchUp to Vizard tutorial for information on exporting models for Vizard
Old 08-27-2020, 05:19 AM
wbs wbs is offline
Dear Jeff,
Thanks for your reply. How can I post my screenshot? I think my model is correct in Inspector.
Old 08-27-2020, 07:51 AM
The model should look the same in Vizard as it does in Inspector. Try running a simple script that just loads the model without any other code. How does that look?
Old 08-29-2020, 05:01 AM
wbs wbs is offline
Dear Jeff,
Do you know how to adjust ground size, my model is bigger than the ground. I want to enlarge ground size. Thanks
Old 10-05-2020, 04:02 PM
kennethkarthik kennethkarthik is offline
Moderator
Hey wbs,
Sorry for the delay. You can use the setScale function on any node 3d object like the ground or a model. Simply use it in the following syntax:
<node3d>.setScale( [x,y,z] )
where [x,y,z] specifies the scale factor that is applied independently to each of the three dimensions.
see the documentation for further information
Binocular overlap Oculus Rift DK2 willpower2727 Vizard 2 08-19-2015 05:18 AM
viz.Screen Images overlap and Interface Button jaylocco Vizard 1 08-28-2009 03:18 PM
how to create ground? guxmy01 Vizard 1 06-17-2008 10:38 AM
Stereo Overlap question JMOwens Vizard 2 01-08-2008 08:54 AM
