Old 11-04-2015, 02:09 AM
hzhao hzhao is offline
how to record data at fixed rate with viz.starttimer
HI,
I use viz.starttimer(0,1/30,viz.FOREVER) to run my object animation and record the motion data in function myAnimation. But the data is not recorded at 30Hz. instead it is recorded at about 40Hz and fluctuates.
viz.callback(viz.TIMER_EVENT,myAnimation)
I use Oculus DK2. If my virtual scene is complex and the computing burden is high, the data recording rate drops. So I set it at 1/30, and want to have a fixed recording rate. But it doesn't work.
Thanks.
Old 11-04-2015, 06:55 AM
mape2k mape2k is offline
The script updates every frame: if the framerate drops below 30fps, the recording rate will also suffer.
You can decouple this by using the viz.director to start the data recording in a whole new thread, but it will be time asynchronous from the main thread so be careful.
Cheers!
Vsync prevents using fresh motion capture data in physics simulations? performlabrit Vizard 2 11-05-2013 10:48 AM
Physics engine update rate and display rate zharuViz Vizard 12 10-28-2013 06:52 AM
Frame rate issue kopper Vizard 2 06-09-2013 10:53 AM
Use saved text file data as replay sources problem mizutani_jun Vizard 4 10-14-2010 04:49 PM
record and playback head-tracked data michaelrepucci Vizard 3 11-25-2008 04:20 PM
