Exporting materials from 3DS Max
I am using the Worldviz Cal3D exporter for 3DS Max, following the suggested tutorial to export a character. This has worked fine in the past. Now I am having problems with the materials - the character shows up entirely black in Vizard (no warning / error messages).
The character I am using is f028 from the Rocketbox Complete Characters HD casual set. In the Max file there are multiple meshes for different LOD. In the Material Editor there are two scene materials: 'f028' and 'f028_opacity'. Attempting to keep things simple, I am ignoring the opacity for now. This is the process I followed: Show scene material f028 in Material Editor Rename materials to f028_head [0] and f028_body [1] Got to Edit > Select By > Layer... f028_hipoly_81_bones Export mesh as .CMF Export materials as .CRF, adding 'Maps\' as the subfolder in the file name Paste relevant .tga files into the Maps folder Write .CFG file I've also tried selecting the same mesh plus the opacity mesh and exporting the selection as one .CMF file, then exporting the materials in 'f028' and 'f028_opacity' in all possible combinations, but none have worked. |
Be sure to check if the diffuse color of the materials is white. I'm not sure if Worldviz changed that already for the CCHD pack, but I know my Rocketbox characters default to black.
The diffuse color seems to be used by Vizard as a sort of luminance value for the texture; black will render the texture really dark (or just black, in fact), white will render it normally. |
It worked, amazing!
Many thanks! |
Similar Threads | ||||
problems exporting casual_01_f avatar | armo | Vizard | 5 | 10-29-2014 09:31 AM |
Exporting Mult-Sub Obj Textures from references in Max using IVE/OSG | shivanangel | Vizard | 3 | 02-10-2010 01:09 PM |
Problem exporting to Cal3d from Max 8 | dropshadow79 | Vizard | 3 | 01-13-2010 11:16 AM |
Trouble Exporting to .ive | le perdusier | Vizard | 2 | 11-27-2007 04:31 PM |
Multi/Sub-Object materials in MAX | tolek | Vizard | 4 | 11-06-2007 10:28 AM |
