Old 08-26-2005, 11:53 AM
Amit Amit is offline
changing the color of Shirt of Vizard Avatars
Can the default color of the shirt of inbuilt vizard avatars be changed? and how?
-Amit Parkar
Old 08-30-2005, 10:26 AM
tobin tobin is offline
No, the color of the shirt cannot be changed in a very straightforward manner. The two things you can do are change the color of the underlying geometry which will blend somewhat into the texture. Or, you can apply a new texture to to the avatar but unless you have purchased the avatar Max models, this would mostly be an exercise in frustration because aligning the texture coordinates would be hard.
Bottom line, the avatars included with Vizard are meant to be used as is. They are based on the Cal3D standard so you can create your own or purchase a PeoplePak from WorldViz and obtain full access to the avatar's mesh and textures.
Old 09-02-2005, 08:00 AM
Thank you very much for the information
-Amit
