Old 02-19-2015, 10:35 AM
JB_HP_Viz JB_HP_Viz is offline
How to map HTML button to Transport in Vizconnect
I’ve setup an HTML page with a button on it using vizhtml
<input id='forward' type=button value="Forward">
And when that button is clicked it sends a message to Vizard
$("#forward").click(function() {
socket.send( 'forward' , viz.Data({}) );
Is there a way to map this HTML button to the Driving Transport in the vizconnect configuration file instead of mapping an input device like a keyboard or Joystick to the Driving Transport?
Attached JPEG shows mapping Keyboard keys to Driving Transport, I would like to be able to map an HTML button. Is there a way to setup a Driving Transport and then map HTML button in the code?
Thank you
John
Old 02-23-2015, 05:33 AM
This is not possible through the vizconnect GUI but should be possible by manually modifying the config file. I'll try and post a simple example soon.
Old 02-23-2015, 10:26 AM
Thank you. That would be great if you can provide an example.
Old 02-24-2015, 07:38 PM
In the attached example the transport is defined in the vizconfig file but the transport's update function is moved to the main script. In the main script, there is a class which stores the button states. The update function moves the transport based on these button states.
Switching between input devices setup in vizconnect and not using vizconnect JB_HP_Viz Vizard 1 01-20-2015 05:19 AM
Vizconnect Save As Dialog Jeff Vizard 0 05-01-2014 09:45 AM
A door question... left button mouse Sakiot Vizard 3 08-26-2011 12:45 AM
Create Button or Text Chrissy2009 Vizard 1 07-15-2009 05:34 PM
button problems cade_mccall Vizard 3 02-22-2007 09:48 AM
