Turn on Collision, but still can go through
This is a weird thing. I turn on the collision using viz.collision(viz.ON), and all of the objects inside the boundary are impenetrable. But the problem occurs on the boundary. When I go really hard to the wall, sometimes I can go through!?
Does anybody have this experience? I use google sketchup to make the objects. |
How are controlling the viewpoint movements? Does the viewpoint go through when using the standard mouse navigation with default speed?
Thank you for your prompt reply!
Yes. I use vizcam.KeyboardCamera with default speed and viz.WalkNavigate, and both of them would go out of the boundary if I keep hitting the wall. I also implement the joystick version, same result. But I have to emphasize that it only happens when you try to hit the wall for more than 1 second. |
Oh, you are a genius. Thanks!
Similar Threads | ||||
Turn off collision of mainview partially | Marco | Vizard | 2 | 05-30-2014 04:02 AM |
Collision Exception | jassel41 | Vizard | 2 | 11-09-2010 05:08 PM |
Collision and avatar animation | shahramy | Vizard | 2 | 10-26-2010 11:47 PM |
Collision notifications | CarlosRamos | Vizard | 3 | 05-25-2010 02:33 PM |
Collision with child nodes | rubberpimple | Vizard | 4 | 09-17-2008 04:27 PM |
