External package problem from Vizard Package Manager
Dear Forum,
Has anyone had problems using packaging that has been downloaded and installed via the package manager in Vizard? I recently installed the pykalman package and when I try to run a very simple script to see if the package is working properly (just importing viz and pykalman modules before calling viz.go() ) and I get this error message: Code:
****************************************************************************** ** Loading pykalman_test.py ****************************************************************************** Traceback (most recent call last): File "<string>", line 11, in <module> File "C:\SWIG_EXAMPLE\HapticMaster\HapticMasterEx\tpose_reset_demo\pykalman_test.py", line 2, in <module> import pykalman File "C:\Program Files (x86)\WorldViz\Vizard4.10\bin\lib\site-packages\pykalman\__init__.py", line 10, in <module> from .standard import KalmanFilter File "C:\Program Files (x86)\WorldViz\Vizard4.10\bin\lib\site-packages\pykalman\standard.py", line 12, in <module> from scipy import linalg File "C:\Program Files (x86)\WorldViz\Vizard4.10\bin\lib\site-packages\scipy\linalg\__init__.py", line 159, in <module> from .misc import * File "C:\Program Files (x86)\WorldViz\Vizard4.10\bin\lib\site-packages\scipy\linalg\misc.py", line 5, in <module> from . import blas File "C:\Program Files (x86)\WorldViz\Vizard4.10\bin\lib\site-packages\scipy\linalg\blas.py", line 145, in <module> from scipy.linalg import _fblas ImportError: DLL load failed: The specified module could not be found. ** Load Time: 0.15 seconds Has anyone else come across this before? Regards, Peter |
Please forget the above post. I have just solved the problem! There was a problem with the SciPy package and I resorted to a full package from the sourceforge site and everything works fine now!
Similar Threads | ||||
Vizard problem | mizutani_jun | Vizard | 4 | 01-09-2011 03:39 PM |
Vizard tech tip: Using the Python Imaging Library (PIL) | Jeff | Vizard | 0 | 03-23-2009 11:13 AM |
newbie problem getting vizard to work | Colin | Vizard | 2 | 11-10-2006 10:54 AM |
problem talking to usb device in Vizard | Vbents | Plug-in development | 2 | 06-15-2006 03:08 PM |
Vizard Crashes: causes are hard to determine, possible problem with the viz code | vr_boyko | Vizard | 1 | 01-07-2005 10:52 AM |
