Old 09-20-2013, 11:35 AM
teklab teklab is offline
Oculus Rift Fullscreen
Hi all. We have just started using our Oculus Rift with Vizard code, and I'm trying to understand a full screen rendering issue.
If i run a basic environment script with the Oculus:
import oculus
hmd = oculus.Rift()
sensor = hmd.getSensor()
viz.link(hmd.getSensor(), viz.MainView)
#vizact.onkeydown('r',sensor.reset)
floor = viz.add('ground.osgb')
and maximize the view window manually (Windows Key + ↑), the frame rate and overall experience during head rotation is very smooth. However, if I use the same script, and instead start the rendering environment with viz.go(viz.FULLSCREEN), the world becomes a great deal more choppy.
Moving to full screen manually isn't a major issue, but is there a way to smooth out the viz.go(viz.FULLSCREEN) option? Maybe my code isn't organized properly, or I'm missing an option.
We are running an i7-2600 with a gtx 580, so I can't imagine it's a hardware limitation for rendering such a simple environment.
Old 09-23-2013, 11:00 AM
If you don't connect to the sensor do you still get choppy results with rotations?
import oculus
import vizcam
hmd = oculus.Rift()
piazza = viz.add('piazza.osgb')
vizcam.PivotAnimate(pivot=[0,1.8,0])
What is the framerate when you have this rendering issue (press F4 with script running)? Do you have the latest drivers for your graphics card?
Old 09-23-2013, 11:36 AM
Jeff,
I re-ran everything today, and the issue seems to have spontaneously resolved. Locked at 60FPS (with vsync enabled) regardless of how I start it now.
Thanks for the reply.
Old 05-19-2014, 08:15 AM
disbeat disbeat is offline
Hi everybody,
I have the same issue...
Do you have any idea on how it was solved?
I go from 60fps to ~20 to 30 fps when on fullscreen...
Best,
Marco
Old 05-19-2014, 08:31 AM
sorry, it's not quite the same error...
I have a decrease of FPS and user experience when I fullscreen the scene, disregarding of how the fullscreen is triggered...
Do you think it is a hardware issue? I have a nVidea Quadro FX 580 and I'm rendering the piazza with an HD avatar.
Old 05-20-2014, 05:08 AM
Erikvdb Erikvdb is offline
What are your update/cull/draw/GPU times? You can check by pressing F4 twice. If your GPU takes more than 16ms to render a frame, framerate will decrease. If that's the case then I'd suspect your graphics card is indeed not fast enough.
Old 05-21-2014, 06:11 AM
I think it is indeed an hardware issue.
When I run it on the production computer, I achieve 60FPS. Only in the development computer I got the 30~40FPS.
Thanks all,
Marco
Oculus Rift and 360 Panorama with Vizard Lite Edition mshukun Vizard 4 11-10-2015 11:17 AM
Can I have fullscreen when using wx? Renato Lima Vizard 0 03-02-2011 06:10 PM
Fullscreen HMD Stereo with Vista64 xabbu Vizard 0 06-30-2009 06:24 AM
White Fullscreen crash when running network version Dbuckland Vizard 6 04-19-2006 02:49 PM
Fullscreen mode is kaput FlyingWren Vizard 4 11-06-2003 07:02 AM
