Old 11-13-2013, 01:36 PM
javadi javadi is offline
Set Mouse Position
Dear all
In occasions, I need to set the position of the mouse to a certain location in the screen. I noticed that Vizard has some functions for getting mouse position. But I couldn't find anything for setting mouse position. I know that there are other libraries such as ctypes and win32api that you can use for setting the mouse position. I am wondering whether there is anything implemented in Vizard. Very many thanks.
Greetings :-)
Amir
Old 11-15-2013, 05:04 PM
Try the following:
import win32api
import win32con
x=0.1
y=0.9
win32api.mouse_event(win32con.MOUSEEVENTF_ABSOLUTE|win32con.MOUSEEVENTF_MOVE,int(65535*x),int(65535*(1.0-y)),0)
Old 11-19-2013, 03:59 AM
Hi Jeff
Very many thanks for the code. What is the difference between your code and simply using the following code as you also use win32api?
win32api.SetCursorPos((int(x), int(y)))
This is a nice piece of code demonstrating it
import win32api
import time
import math
for i in range(100):
    x = 500+math.sin(math.pi*i/100)*500
    y = 500+math.cos(i)*100
    time.sleep(.1)
Greetings
Amir
Mouse bug in V3 and V4 Renato Lima Vizard 2 05-11-2011 06:38 PM
Mouse event: how to detect no mouse move event, how to set mouse position? Zhi Vizard 3 04-11-2011 06:25 PM
how to remove velocity when mouse is disabled? jvacare1 Vizard 2 02-18-2010 10:25 AM
Navigating an avatar using mouse position(2D) in 3D environment james007 Vizard 1 10-16-2009 11:29 AM
set mouse position AlyssaK Vizard 1 01-28-2009 04:05 PM
