Old 11-04-2013, 05:00 AM
royb royb is offline
System stopped recognizing position (while orientation still works)
When running a program (I tried several, including the elevator demo) the system seems to not recognize position anymore: link.reset(viz.RESET_X | viz.RESET_Z) doesn't work, and when the marker moves no movement is registered on the screen.
However, orientation keeps working fine - orientation reset works and when the marker (helmet) changes orientation, so does the view on the screen (so I don't think it's a communications issue).
Nothing changed really since the last time the system was functioning properly and I have no idea what to try next...
Any advice?
Roy
Old 11-04-2013, 05:34 AM
Or it might really be a communication issue
between the PPT computer and the worldviz computer. How do I test it?
Old 11-06-2013, 06:00 AM
Nevermind
Problem solved - I had to configure the PPT output to VPRN7... no idea how it changed...
problem in setting the orientation of bones bharatbhushan Vizard 0 06-30-2009 04:30 AM
Position and Orientation tracking problem Vic Vizard 1 06-09-2009 05:13 PM
Can you link the position of a tracker to the orientation of an object? michaelrepucci Vizard 1 09-19-2008 10:23 AM
Flock of Birds (Only Position Tracking working? No Orientation?) TheLostBrain Vizard 6 05-10-2008 08:39 AM
