Old 12-15-2011, 06:59 AM
madeinjava madeinjava is offline
Arrow Keyboard Shorcut
Hi all,
I need to make some keyboard shortcut (instead a single button) into my VR world. Its work fine when only using single button shortcut like this:
def onKeyDown(key):
if key == 'c':
print 'Hello World!'
However I want to assign a standard windows shortcut, like: Ctrl+z, Ctrl+v, or maybe just 2 or 3 button combinations ('a'+'b' button, etc.)etc.
How I can implement this? I tried using:
if key == viz.key.allDown(['a','b']):
I tried using anyDown() as well but none of this works.
Any suggestion what should I do? or I made a mistake there?
Thanks alot!
Old 12-20-2011, 04:34 AM
Smile Solved! :)
Originally Posted by madeinjava View Post
Hi all,
def onKeyDown(key):
if key == 'c':
Thanks alot!
Problem solved!
Basically I need to 'listen' first from keypress (using onKeyDown) and then checks every keyhits on allDown or anyDown function.
Ps. thanks to clevr team for give me the hint
User keyboard input without halting the program Zhi Vizard 2 06-23-2011 12:53 PM
Keyboard shortcuts for debugging kopper Vizard 6 03-25-2011 05:23 PM
Question about input from virtual keyboard. yyang Vizard 4 12-23-2008 12:25 PM
On Screen Keyboard betancourtb82 Vizard 14 10-03-2006 12:38 PM
Multiple Viewports in Vizard, Utilizing keyboard callback shivanangel Vizard 2 02-21-2006 04:56 PM
