WARNING: Failed to set media volume (Unspecified error)
hi all,
i use the following sample code: sound = viz.addAudio('bach_air.mid') sound.loop(viz.ON) sound.volume(.5) sound.setTime(3) sound.setRate(2) sound.play() and it will show me this error: WARNING: Failed to set media volume (Unspecified error) Please help me. Thank you so much. |
This seems be to be an issue specific with the midi format. It should work if you convert the file to another format.
hi Jeff,
but my project require only midi format. Is there other way to adjust volume for midi file? Thanks. |
Similar Threads | ||||
ERROR: Failed to load .ive file | turgutm | Vizard | 1 | 09-16-2010 05:16 AM |
ERROR: Failed to initialize python | kay | Vizard | 1 | 10-07-2009 11:51 AM |
5DT glove ultra error 5dt.dls failed | kabk | Vizard | 2 | 05-05-2009 12:43 PM |
Warning:: Picked up error in TriangleIntersect | Mike Konstant | Vizard | 1 | 07-07-2008 02:32 PM |
PPT talk button error: Failed to connect to COM4 | jpq | Precision Position Tracker (PPT) | 3 | 12-08-2005 02:36 PM |
