Old 07-21-2011, 06:03 AM
TarkaDahl TarkaDahl is offline
Transparent png broblems
Im having a problem when using pngs with transparency. You can see through objects behind.
The grass is on a plane however you can see through the bushes in background and can see the grey backgound image. This happens in inspector aswell.
This happens as well in other places as well when we have a semi transparent png as a water surface. Certain objects in the water then disapear.
Any help would be appreciated.
TarkaDahl
Old 07-22-2011, 12:19 AM
sleiN13 sleiN13 is offline
Sounds like a drawOrder problem. Have you tried to assign different draworders yet?
.drawOrder(number, bin=viz.BIN_TRANSPARENT)
Old 07-22-2011, 01:40 AM
Hi sleiN13
Ive had tried draworder previously but i will retry it.
Old 07-28-2011, 10:10 AM
Is the grass plane the only object in your model that contains transparency? If you have multiple transparent objects that intersect each other, then you will have these kinds of issues.
To solve these kinds of problems, we usually break up the transparent objects into smaller pieces. This gives the rendering engine more fine-grained control with the order in which transparent objects are rendered.
If you continue to have problems, you can post your model here, or use our upload form, and somebody can take a look at it.
Old 08-01-2011, 03:12 AM
Hi farshizzo,
I will try that today.
Also is there any way to change my spelling mistake in the title.
Make an object transparent if you see it from its back Renato Lima Vizard 3 11-18-2010 02:36 PM
Glass (transparent materials) cantwelljm Vizard 1 03-08-2006 01:39 PM
3d Text with Transparent Borders vjosh Vizard 3 12-01-2004 10:50 AM
TRANSPARENT MASKS not transparent Vhihu Vizard 3 11-05-2004 02:11 PM
