Old 06-27-2011, 11:35 AM
Aweless Aweless is offline
Setting the origin of a object to an object's center
In short I've loaded a square into vizard (.dae). The square's origin is not in the center of the square, but in it's top left hand corner. This is because of when it was exported that corner of the square was at the origin of the viewport. Is there a way for me to determine the center of the square in vizard and relocate it's origin to it's center? Pretty I just to fix this so when I move or rotate the object it move with respect to it's center.
I included a jpg displaying my problem. I am aware if I re-export the square realigned it will fix the problem, but I can't for various reasons.
Old 06-28-2011, 12:57 AM
sleiN13 sleiN13 is offline
If it is a square alignes with the axis getBoundingBox() might do.
Just get the box.size and do a translation of half the width, height and depth and you should be oke
How to move a text object and its children text objects as a whole knightgba Vizard 2 08-24-2010 10:21 AM
Positioning objects: center johannes2 Vizard 2 02-12-2008 02:56 AM
Center Viewport on Object (5DT Glove) bjgold Vizard 3 07-25-2006 03:22 PM
