Debug error
I managed to get some code running using the Run Script option, but when I tried to debug, I got the following error (related to the Queue object) Code:
Traceback (most recent call last): Traceback (most recent call last): File "C:\Program Files (x86)\WorldViz\Vizard4\python\vizbdb.py", line 271, in start File "C:\Program Files (x86)\WorldViz\Vizard4\python\vizbdb.py", line 359, in message_loop id,data = self.wait_for_message([_DM_INITIALIZED]) File "C:\Program Files (x86)\WorldViz\Vizard4\python\vizbdb.py", line 381, in wait_for_message id,data = self.message_queue.get() AttributeError: 'Queue' object has no attribute 'get' ** Load Time: 0.01 seconds self.handle_message(id,data) File "C:\Program Files (x86)\WorldViz\Vizard4\python\vizbdb.py", line 338, in handle_message self.message_queue.put((id,data)) AttributeError: 'Queue' object has no attribute 'put' Exception in thread Thread-1: Traceback (most recent call last): File "C:\Program Files (x86)\WorldViz\Vizard4\bin\lib\threading.py", line 530, in __bootstrap_inner self.run() File "C:\Program Files (x86)\WorldViz\Vizard4\bin\lib\threading.py", line 483, in run self.__target(*self.__args, **self.__kwargs) File "C:\Program Files (x86)\WorldViz\Vizard4\python\vizbdb.py", line 364, in message_loop self.message_queue.put((None,None)) AttributeError: 'Queue' object has no attribute 'put' Christian |
The error AttributeError: 'Queue' object has no attribute 'get' is suspicious. It seems like something is conflicting with the Queue module that is part of the standard library. Do you have a module in your script directory that is called Queue?
Oops, you are quite right - somebody did create a Queue class at some point. I'll have to change that.
Christian |
Similar Threads | ||||
ERROR: Failed to load .ive file | turgutm | Vizard | 1 | 09-16-2010 05:16 AM |
5DT glove ultra error 5dt.dls failed | kabk | Vizard | 2 | 05-05-2009 12:43 PM |
Howto debug a custom plugin? | reedev | Plug-in development | 3 | 04-23-2009 02:16 PM |
Loading morph mesh error. | vEsotu | Vizard | 2 | 03-14-2009 06:29 PM |
The error window that couldn't | FlyingWren | Vizard | 2 | 12-02-2003 08:23 AM |
