Old 02-16-2011, 12:14 AM
mizutani_jun mizutani_jun is offline
Unhappy Question about cluster replacement
Hi.
I want to ask about cluster replacement.
Right now i`m using 4 computers,3 coms for show screen and 1 com for gui.
Until now i`m using cluster mode for all 3 coms and just only need to set main view euler for all 3 coms.
The problem now is i want to use all this 3 com as exe file,so i tried publish as exe for all but seems all com view set only to one view.
After some search,i found that cluster mode can`t be one of the client in exe mode.
Can i know if there is any reason behind this?
I really need to publish all my work in exe so now i`m searching for replacement for cluster mode.
1 from 3 computer that i use for show screen is connecting to patriot and all the data save in this com.
How can i connect all my com just like i did in cluster mode without losing all the function in this mode?
Hope someone can help.
Thanks.
Old 02-18-2011, 02:49 PM
mspusch mspusch is offline
Hi, the cluster mode only works with Vizard Enterprise licensed on each of the cluster nodes, its' a feature that only Vizard Enterprise has and that cannot be compiled into an EXE.
Question about GUI and CLUSTER mizutani_jun Vizard 2 01-02-2011 03:35 PM
How to run Demo exe on 3 channel cluster Azlan.Vrs Vizard 3 04-27-2009 11:06 AM
Cluster Help videcuk Vizard 12 09-21-2007 02:14 PM
quad_buffer cluster John P Vizard 4 06-07-2006 10:01 PM
