Old 06-08-2010, 12:04 PM
llqqff llqqff is offline
Creating the sound effect
I am working on how to play the sound in vizard that can change the volume when the distance of two objects changes which means: I have a target in some position and I move my right hand, when my hand is moving closer to the target, the volume of the sound increases, otherwise decreases.
I know the target.playsound() function, which can calculate the distance between the target and the two LEDs, then play the spatialized sound automatically.
And now I know how to calculate the distance between the target and the hand, but I don't know how the change the volume when the distance changes.
Old 06-08-2010, 12:28 PM
Are you saying you want to use the <node3D>.playsound command but also manipulate the sound volume yourself? If so, look at the following:
ball = viz.add('ball.wrl',pos = [0,1.8,2])
slider = viz.addSlider()
slider.setPosition(0.5,0.2)
slider.set(1)
sound = ball.playsound( 'boing!.wav', viz.LOOP )
def changeVolume(value):
	sound.volume(value)
vizact.onslider(slider,changeVolume)
Old 06-08-2010, 12:52 PM
Actually, I don't want a slider, I want the volume changes automatically when the distance of the hand and the target changes, is there anyway to do that?
Sound Looping Problem JMOwens Vizard 4 09-29-2010 09:42 PM
Attaching sound to a moving object GiudiceLab Vizard 6 08-21-2009 08:52 AM
Multiple Sound Devices GiudiceLab Vizard 2 06-06-2009 10:29 AM
Stuttering sound Jerry Vizard 1 06-13-2007 12:36 PM
sound problem alaa Vizard 7 09-02-2005 01:13 PM
