Old 09-19-2018, 09:52 AM
jwhopkin jwhopkin is offline
Animation path translate modes
I am currently using animation paths to translate certain objects. If I do not use paths and just use the setPosition() command on the object itself with the mode viz.ABS_GLOBAL, it places the object where I need it to be. However, when using the animation paths, I seem to be unable to specify the translation mode. I tried using the controlpoint.setPosition() function, which takes the argument viz.ABS_GLOBAL without error, but it does not place the object in the proper place (it translates the objects as though i did not specify the mode in the first place)
Thanks for your help!
Old 09-25-2018, 03:49 AM
Can you provide some example code that shows the issue?
animation, mode, path, translate
problem with yield statement and animation path jelly Vizard 2 05-05-2016 09:13 AM
animation path problem - coordinates not resetting jelly Vizard 7 04-26-2016 10:45 AM
problem with path animation jelly Vizard 5 04-20-2016 06:15 AM
Road Animation Path vserchi Vizard 4 11-12-2015 09:29 AM
speed on animation path whj Vizard 8 11-17-2008 07:41 PM
