Old 03-16-2015, 10:36 AM
BSUGeek BSUGeek is offline
Question Help with the slider
I'm having trouble using the slider to change the speed of my viewpoints movement. While i'm moving i want to be able to use the slider to increase or decrease my movement speed. How can i do that?
Old 03-16-2015, 10:47 AM
What are you using to move around?
Just grab the sliders value
pos = slider.get()
Multiply by some movement speed to make the value larger than 0 to 1
Set the speed equal to the newly calculated rate/force/speed/etc.. you are using to move around the environment with.
Old 03-16-2015, 11:04 AM
Here's the code i have so far. I'm not sure how i should have my move_speed increase and decrease with the slider
MOVE_SPEED = 60
TURN_SPEED = 60
sliderPanel = vizinfo.InfoPanel(text=None, icon=False)
slider = sliderPanel.addLabelItem('Speed', viz.addSlider())
slider.set(0)
def mySlider(pos):
vizact.onslider(slider,mySlider)
def updatecar():
    #move view forward and backward
    if viz.key.isDown(viz.KEY_DOWN):
        view.move([0,0,MOVE_SPEED*viz.elapsed()],viz.BODY_ORI)
    if viz.key.isDown(viz.KEY_UP):
        view.move([0,0,-MOVE_SPEED*viz.elapsed()],viz.BODY_ORI)
	#rotate body of view left and right
    if viz.key.isDown(viz.KEY_RIGHT):
        view.setEuler([TURN_SPEED*viz.elapsed(),0,0],viz.BODY_ORI,viz.REL_PARENT)
    elif viz.key.isDown(viz.KEY_LEFT):
        view.setEuler([-TURN_SPEED*viz.elapsed(),0,0],viz.BODY_ORI,viz.REL_PARENT)
vizact.ontimer(0,updatecar)
Old 03-16-2015, 11:09 AM
For the easy way out, you can read the state of the slider in the updateCar method.
If you multiply the movement speed by the slider value, it will allow you to scale between 0 and your max speed, which is 60 in this case.
view.move([0, 0, MOVE_SPEED*slider.get()*viz.elapsed()], viz.BODY_ORI)
Do this for each movement call you make. You are now scaling the speed of the car by the amount of time since the last update and the value of the slider.
Old 03-16-2015, 11:15 AM
Thumbs up
that worked great! thanks alot for your help!
Old 03-16-2015, 11:19 AM
Is there a way to show your speed on the screen as it's changing?
Old 03-16-2015, 11:23 AM
Create a text object on the screen.
Look up text node basics in the Vizard help file.
Grab the value and set the text equal to it.
Slider Assistance new_horizon Vizard 3 05-16-2012 07:32 AM
adding more than 1 action for avatar animation slider control yak Vizard 0 07-21-2009 11:22 AM
help with slider code yak Vizard 2 07-20-2009 12:12 PM
Vizmenu slider bug? Gladsomebeast Vizard 2 10-22-2008 08:05 PM
Blending/Fading 5 Textures with a Slider south_bank Vizard 2 05-15-2008 07:59 AM
