Old 02-03-2015, 01:59 AM
viz viz is offline
Arrow Script does not terminate
Hello
I am using Tkinter, whenever I close any window the script remains running and it does not terminate.
This is a huge issue for me any solutions?
Regards
Old 02-03-2015, 07:48 AM
Take a look at this thread for an example script that embeds the Vizard window in a Tk application.
Old 02-04-2015, 01:27 AM
viz viz is offline
Hello
I am not facing coding issues with Tkinter I am able to use it, the problem is that any script that uses Tkinter does not terminate when I close the script.
Regards
Old 04-06-2015, 06:56 AM
willpower2727 willpower2727 is offline
Yes I'm having the same problem. It seems that calling root.destroy() should terminate the tkinter mainloop. However in Vizard mine keeps running regardless. Not even sys.exit() does anything
Old 04-09-2015, 05:49 PM
Can you post an example script that replicates the issue for you?
starting Vizard from a Python script hotspur1 Vizard 12 06-12-2019 12:03 PM
Python script latency after exiting when using InterSense IC2+ fordprefect Vizard 1 03-18-2014 11:58 PM
How are files associated/how should they be saved (python script + images) mhead10 Vizard 1 03-26-2012 10:58 AM
Simplest script not working vasiliys Vizard 2 10-25-2011 10:24 AM
script file available - but missing spdegabrielle Vizard 1 05-06-2009 10:04 AM
