Old 11-26-2018, 08:14 PM
Vishav Vishav is offline
How to remove myTimerAction?
I am using this command in some function
myTimerAction = vizact.ontimer(8,dotappear)
and my function dotappear is:
def dotappear( ):
global point
point=viz.addText3D('o',pos=[1.24,0.78,0.4],scale =(0.01,0.01,0.01),color=(0,1,0))
and after 8 seconds dot appear on the screen.
After some if condition satisfies I want to remove/invisible point using:
if(trial_time>=15):
point.visible(viz.OFF)
But the point is not getting removed. Why?
Old 11-28-2018, 08:30 PM
The function registered with vizact.ontimer will get called every 8 seconds. So you could be adding the point multiple times. In that case removing the point will only remove the last one added. If you want the callback function called only once, use the vizact.ontimer2 command instead.
Old 12-05-2018, 04:49 AM
Thanks Jeff
how to remove Oculus warning message? hzhao Vizard 1 10-19-2015 05:50 AM
camera view remove flying robot robgulwell Vizard 0 11-15-2011 01:01 AM
vizdlg Panel: Add and remove disbeat Vizard 2 02-08-2011 12:44 PM
How to remove the head from avatar Xianshi Xie Vizard 2 06-22-2009 09:05 AM
How to remove a modifier Joran Vizard 1 05-27-2009 12:53 PM
