Old 01-29-2016, 05:32 AM
SWarren SWarren is offline
Scene render issue - Information disappears when rotating
I am using the trial version of Vizard (5.2) with the intention of using our revit and pointcloud information with the Oculus DK2. I have added a rvt file and it works great, but when I add a 3DC file of our point cloud, the image will only show on 1/2 the view able area, once you pass this threshold, the grabber and the data disappear. This only happens when I add the 3DC file, and not when using the rvt file alone.
If i rotate the screen about the Z axis 0d-180d is fine, but 181d-360d makes everything disappear. My 3DC file is a PTS file which has the extension renamed.
Thank you for your time,
S. Warren
Old 01-29-2016, 08:39 AM
The issue in this thread sounds similar. Perhaps changing the clipping plane will help.
3dc, pointcloud, rvt
Setting up render node for shadowing whaleeee Vizard 2 05-06-2013 10:20 AM
Copying Scene? Brett Lindberg Vizard 0 08-28-2009 11:56 PM
How to access scene information in a C++ modifier m7ossny Plug-in development 1 03-23-2007 11:02 AM
