Old 09-15-2022, 02:02 PM
Pegasus3 Pegasus3 is offline
Which format I can use Avatar in Vizard???
Hello all,
I am trying to use an Avatar in Vizard using either of the two options:
(1) Use fbx file and save as osgb but vizact.speak is not working for .osgb file
(2) Use Cal3D exporter but the exporter is not available for latest 3dsMax version.
How I can use Avatar in Vizard that can support lip-synch. I urgently need to submit my project. Any lead would be helpful.
Old 12-10-2022, 11:09 AM
sado_rabaudi sado_rabaudi is offline
Does your model contain facial morphs? You can see that in Inspector on the right hand side if you click on the name of the avatar.
.fbx is the most compatible format
Unexpected Avatar lookAt() behavior when using yield statements chris2307 Vizard 2 12-17-2013 02:58 AM
add 3dmax avatar in Vizard Gonzalo Vizard 1 09-23-2011 04:44 AM
Clarification on CAL3D Avatar Animation in Vizard shivanangel Vizard 2 11-22-2010 07:16 AM
Copyright ©2000 - 2023, vBulletin Solutions, Inc.
