Old 08-26-2009, 01:24 AM
lilio lilio is offline
Change Viewpoint in different scenes
Good morning,
I want to change the viewpoint from scene to scene. So I want to set in scene1:
viz.MainView.setPosition(0,0,-10)
viz.MainView.lookat(0,0,0)
If I change the scene to scene 2, then the viewpoint should be set to
viz.MainView.setPosition(0,4,-7)
viz.MainView.lookat(0,7,0)
viz.scene( 2 )
This is okay. But if I want to change back to scene1 and make
viz.scene( 1 )
then it does not work.
I've tested it with this
print viz.MainView.getPosition()
and I can see that the viewpoint will be changed from scene1 to scene2. But back to scene1 it does not change. Why???
Thanks!
Old 08-28-2009, 02:56 PM
Can you post a fully functional script that replicates your problem?
How to track the actual viewpoint Jerry Vizard 3 05-25-2016 09:44 AM
Avatar w/ hat cannot look at viewpoint TrashcanPatrol Vizard 5 08-19-2008 08:26 AM
3d viewpoint movement spacefarer Vizard 9 07-25-2006 03:37 PM
VRML Viewpoint error bstankie Vizard 1 03-11-2003 02:10 PM
