Old 01-20-2017, 05:01 PM
Canucks Canucks is offline
Optotrak and vizard
We are doing a project and I'm hoping you can give me some feedback . In our project, the research participant wears the optotrak on his leg and walks on the treadmill. There is a 3D screen in front of him which is an empty room full of obstacles such as step , boxes ... we are trying to measure how high the person lift is leg for each obstacle
Should I use an avatar and the avatar reads the location from optotrak ( so when person moves , avatar moves too) ? If yes , does avatar has a function for lifting leg and doing steps?
If not how do you do this ?
Old 01-23-2017, 11:57 AM
Do you want the participant to be able to see an avatar representation or do you just want to record the sensor data?
Old 01-23-2017, 01:53 PM
Just recording the data. Ie: if the participant lift his leg high enough to pass the obstacle
Old 05-01-2017, 01:58 PM
Actually see the avatar..
Old 05-01-2017, 10:18 PM
You can use vizconnect to map the tracker data to an avatar. See the avatars and tools tutorial.
avatar, avatar animation, optotrak, vizard
Connecting Vizard and NDI Optotrak vserchi Vizard 3 02-06-2015 01:04 AM
