Old 03-28-2012, 06:43 AM
krimble krimble is offline
intersense addTracker
Hi all,
I'm having some troubles with a small piece of code. Basically I would like to connect to the Intersense 900 and link my mainview to the tracker and apply a postTranslation to it.
(I'm busy writing an exp. using a usb steering wheel and would like to translate the view using the pedals without losing tracking).
I'm used to working with apparently an old intersense method and in another lab (where the experiment is working fine) with the VRPN.dle method:
PORT_INTERSENSE = 0
isense = viz.add('intersense.dls')
viz.tracker()
and with:
	vrpn = viz.add('vrpn7.dle')
	tracker = []
	for trackerNr in range(50):
		tracker.append(vrpn.addTracker('DTrack@192.168.1.100', trackerNr))
		tracker[trackerNr].swapPos([-2, 3, 1])
		tracker[trackerNr].swapQuat([2, -3, -1, 4])
	#	tracker[Nr].setBufferSize(2)
	mv = viz.link(tracker[1], viz.MainView)
I saw the message that I should use:
tracker = isense.addTracker(port=1)
instead of:
viz.tracker()
When I'm using the addTracker function I'm getting the following message:
intersense.dls Intersense Driver v4.0.4
**Connected to Intersense device on port 5001
Type: IS Precision Series
Model: IS-900 Series
Both Station 1 and 2 have the following values:
ON ON 1 2 3 0 0
File "<string>", line 11, in ?
File "intersenseTester.py", line 12, in ?
tracker = intersense.addTracker(x)
AttributeError: 'VizIntersense' object has no attribute 'addTracker'
InterSense is connected on port 1
With the isense.DLE plugin:
intersense.dle Intersense Extension
** Load Time: 1.64 seconds
** ERROR: Failed to connect to Intersense tracker on port 1
** ERROR: Failed to create extension sensor with intersense.dle
am I using an old plugin? How can I make it work with Isense like I did with the VRPN Method.
Many thanks in advance,
Jeroen Derks
Old 03-28-2012, 01:29 PM
Mainly I can't use the addTracker function.
#Add a tracker.
isense = viz.add('intersense.dle')
tracker = isense.addTracker()
#Link the tracker to the view.
viz.link( tracker, view )
Error Message:
Do I need to use a more uptodate plugin? What is wrong?
Thank you!!
Old 03-30-2012, 02:20 AM
Please test with the following short scripts and let us know the output with each.
1.
2.
PORT_INTERSENSE = 0
Old 03-30-2012, 04:51 AM
What do you think it can be?
Thanks for helping me!
Output 1:
** Loading trackerTest.py
** ERROR: Failed to retrieve Intersense station info for station 1
** ERROR: Failed to retrieve Intersense station info for station 2
** ERROR: Failed to retrieve Intersense station info for station 3
** ERROR: Failed to retrieve Intersense station info for station 4
** ERROR: Failed to retrieve Intersense station info for station 5
** ERROR: Failed to retrieve Intersense station info for station 6
** ERROR: Failed to retrieve Intersense station info for station 7
** ERROR: Failed to retrieve Intersense station info for station 8
** Load Time: 3.20 seconds
** ERROR: Failed to auto-detect Intersense, try specifying port number
InterSense Library ver. 4.2110 32-bit
Copyright 1998-2010 InterSense Inc.
http://www.intersense.com
Tel: 781-541-6330
Fri Mar 30 13:47:51 2012
Looking for InterSense tracking device number 1.
Please wait
Looking for UDP Broadcasts
Checking UDP port 5001... FOUND
IS-900 Series device detected on port 5001
Fri Mar 30 13:47:52 2012
Looking for InterSense tracking device number 2.
Please wait
Checking UDP port 5001... IN USE
Checking UDP port 5002... NOT FOUND
Checking UDP port 5003... NOT FOUND
Checking UDP port 5004... NOT FOUND
Checking UDP port 5005... NOT FOUND
InterSense tracker not present
output 2:
Station State Time Cube Enhancement Sensitivity Compass Prediction
1 ON ON 1 2 3 0 0
2 ON ON 1 2 3 0 0
3 OFF ON 1 2 3 0 0
4 OFF ON 1 2 3 0 0
5 OFF ON 1 2 3 0 0
6 OFF ON 1 2 3 0 0
7 OFF ON 1 2 3 0 0
8 OFF ON 1 2 3 0 0
** Load Time: 1.67 seconds
Tel: 781-541-6330
Fri Mar 30 13:49:50 2012
Please wait
Old 04-02-2012, 09:57 AM
Please contact support@worldviz.com for further assistance.
Failed to connect to intersense Karma Precision Position Tracker (PPT) 1 07-01-2011 01:48 PM
Intersense connection blessonisaac Vizard 2 12-06-2010 05:13 PM
Properly aligning the intersense with the PPT Systems Z Axis shivanangel Precision Position Tracker (PPT) 0 11-10-2009 11:35 AM
world is tilting - intersense or code problem? billjarrold Vizard 2 11-06-2009 08:03 AM
intersense with 5DT glove sjp Vizard 2 04-06-2009 07:22 AM
