Old 04-19-2009, 07:25 PM
djones1010 djones1010 is offline
Any ideas on linking chess 3ds file with source code?
All I need now is to link my teams chess pieces/board with the Source Code to drive to drive the pieces.
Rapidshare Link to Source Code
http://rapidshare.com/files/22340446...ss_05.zip.html
Steps to get Source Code working on Vizard
Step 1:
Click these links to download the files need to compile the Source Code in Vizard.
Download files in order as they appear
1. http://s3.worldviz.com/exe/vizard30_tkinter.exe
2. http://www.python.org/ftp/python/2.3.5/Python-2.3.5.exe
3. http://www.pygame.org/ftp/pygame-1.8...in32-py2.4.msi
Old 04-24-2009, 09:56 PM
Need help creating chessboard
The attached file should be placed into VizardChess folder inorder to compile correctly. You can download the VizardChess folder from the link above. It creates one row of white and brown squares then stops. I help completing the rest of the board.
	def Draw(self,board,highlightSquares=[]):
		boardSize = len(board) #board should be square.  boardSize should be always 8 for chess, but I dislike "magic numbers" :)
		current_square = 0
		for r in range(boardSize):
			for c in range(boardSize):
				(screenX,screenY) = self.ConvertToScreenCoords((r,c))
				if current_square:
					pic = viz.addTexture('brown_square.png')
					brown_square = viz.addTexQuad()
					brown_square.texture(pic)
					brown_square.scale(1,1,1)
					brown_square.translate(r-5, 0, 15)
					#self.screen.blit(brown_square,(screenX,screenY))
					current_square = (current_square+1)%2
					pic2 = viz.addTexture('white_square.png')
					white_square = viz.addTexQuad()
					white_square.texture(pic2)
					white_square.scale(1,1,1)
					#white_square.translate(r, 0,15)
					white_square.translate(r-5, 0, 15)
					#self.screen.blit(white_square,(screenX,screenY))
Trying to integrate Source Code with Vizard djones1010 Vizard 1 03-10-2009 02:58 PM
how to use ***.remove() & how to show words directly? (change attach source code) znchb Vizard 2 10-30-2008 12:33 AM
Read file....many issues Uttama_vizard Vizard 9 07-08-2008 02:16 PM
File Management Uttama_vizard Vizard 2 07-01-2008 09:44 AM
