intersection with texquad
If we use texquads as objects that intersect with a ray from the vive controller, is there a way to change the names of the texquads to have something other than "drawable"? Already tried hardcoding the name to something like below, but didn't work: myTexQuad = viz.addTexQuad(size=[1.21, 1.71]) myTexQuad.name = "texQuadCustomName" The intersection with the vive controller is the standard function from the worldviz example for vive that shipped with vizard (below). It returns the intersected object, which could be a VizChild or a VizTexQuad. def IntersectController(controller): """Perform intersection using controller""" line = controller.model.getLineForward(viz.ABS_GLOBAL, length=100.0) return viz.intersect(line.begin, line.end) |
First check to see if the intersected object is the quad, then get the name attribute you assigned to it. Does that work for you?
import viz viz.go() myTexQuad = viz.addTexQuad(pos=[0,1.8,2]) myTexQuad.name = "texQuadCustomName" info = viz.intersect([0,1.8,0],[0,1.8,4]) if info.valid: if info.object == myTexQuad: print myTexQuad.name |
yes, that code works by itself - thanks!
For the purposes of our project, just using the following variant: listOfQuads = [] listOfQuads.append(myTexQuad1) ... if info.object is in listOfQuads: print info.object.name ... |
Thread Tools | |
Display Modes | Rate This Thread |
Determine specific quad from intersection | Novakin | Vizard | 1 | 02-19-2016 01:25 AM |
Attach a TexQuad to pit.osgb screen | Ducky | Vizard | 1 | 01-17-2013 02:57 PM |
TexQuad (viz.screen) and alpha issues | kovitch | Vizard | 2 | 05-17-2012 10:28 AM |
Using a texquad to cover a window | Enlil | Vizard | 4 | 02-07-2012 03:13 PM |
texquad | shai | Vizard | 1 | 02-23-2005 01:09 PM |
