Old 08-09-2005, 02:34 PM
shai shai is offline
vizard 2.5 compatability issue
Hey guys,
say i have an 'avatar' variable, then:
avatar.cal.pose(4) does not work in vizard 2.5.
it seems ".cal.pose()" method does not exist for avatars in vizard 2.5 however it exists in vizard 2.17a...
i was wondering if this is the only compatability issue between the two versions?
tnx,
Shai
Old 08-09-2005, 02:47 PM
In the latest version avatars don't have a cal object associated with them. To set the idle pose you would perform the following:
avatar.idlepose(4)
If you are finding that there are a lot of compatibility issues with your script, then send it to me and I'll update it for you.
Old 08-10-2005, 04:19 PM
Thanks Farshizzo,
there's only one other issue that I have run into, my program now keeps displaying:
** WARNING: Could not find subchild with name: 'm_head.cmx'
although it works fine in the older version. I haven't investigated
the problem completely. But I was just wondering if you by chance know where this might be coming from, if not, I can give you the specific line where this problem is arising.
Shai
Old 08-10-2005, 04:35 PM
This means that some piece of code is trying to access the head mesh of the avatar. Are you using a custom made avatar? If so, then you can ignore this message. This warning message was probably added in the newer version.
