Old 07-19-2018, 04:42 AM
simrus simrus is offline
Vertex array
I generate a minimum of 10,000 lightpoints on every frame (different positions each time). Using numpy I've vectorised every step of my program to get as much speed as possible, but I'm left with this
# now add points to vertex list
for i in range(0, NPTS):
viz.vertex(pt[i,0], pt [i,1], pt[i,2])
which really needs replacing with a single pass of a vertex array.
I see that someone posted previously about this same problem of loops and vertex arrays
https://forum.worldviz.com/showthread.php?p=18081
The underlying OpenGL / OpenSceneGraph has the functionality to pass vertex arrays so is there any (simple) way to expose that functionality in Vizard?
simon
Old 07-25-2018, 08:51 PM
Not that I know of but I will check with a developer for any suggestions.
Old 07-30-2018, 06:04 PM
I've checked and there's no built-in way to accomplish this.
Old 08-15-2018, 02:53 AM
Thanks for checking Jeff. Anyway the functionality could be added to a request list for future versions?
Pass vertex array instead of calling viz.vertex()? Novakin Vizard 2 03-01-2016 12:06 AM
Mesh Graph (more than vertex position info) jpriede Vizard 0 05-03-2013 07:48 AM
vertex list jaclyn.bill Vizard 2 07-01-2009 07:17 AM
Copy objects in an array to another array Johannes Vizard 3 04-29-2005 02:37 PM
