Old 07-14-2015, 01:49 PM
Render to Oculus DK2 desktop mirror only ?
Hello! I'm using vizconnect to setup the Dk2 in direct mode, and would like to render some things (eye-tracking data) to the desktop mirror. I do not want the person in the helmet to see the rendered object.
The issue is that the function vizconnect.getDisplayDict() returns only one display. So, I don't see how it can be done.
How do I render to either the HMD or the mirror alone?
- gD
Old 07-17-2015, 01:44 PM
The window that appears automatically when using the DK2 can't be accessed separately. It's an exact copy of what appears in the HMD. What you could do is run another instance of Vizard on the same machine to open another graphics window. Then add the same environment/models in the control instance and receive network data from the DK2 instance to move the viewpoint.
Multiple post-process effects with oculus rift lklab Vizard 2 03-13-2015 01:48 PM
Oculus runtime disrupts clustering to mirror DK2 display performlabrit Vizard 1 01-23-2015 07:00 AM
Light Baking in 3DS Max causing models to render with seams and transparent faces dproeder Vizard 1 09-17-2013 06:45 PM
Setting up render node for shadowing whaleeee Vizard 2 05-06-2013 10:20 AM
