Old 03-21-2008, 02:03 PM
adimov adimov is offline
Writing text files with executable
I'm trying to generate a text file via an executable but it is not creating a file. Here's the code (the main code, a Parser module and how the the input csv file should look):
import Parser
def CreateTemplate():
# Creates a sequence of zeroes and ones based on the duration and SampleRate and the input data
length = int(duration+1)
print "Duration: " + str(length)
outputsequence = []
for i in range (0, length):
if (i in sequence):
outputsequence.append(1.0)
print "SUCCESS: " + str(i)
outputsequence.append(0.0)
return outputsequence
sequence = Parser.getSequence()
print sequence
duration = max(sequence)
CreateTemplate()
# Opens file 'response.txt' in write mode
file = open('response.txt', 'w')
# Define a function that saves data
def SaveData():
# Create the output string
data = CreateTemplate()
for each in data:
out = str(each) + '\n'
# Write the string to the output file
file.write(out)
# Makes sure the file data is really written to the harddrive
file.flush()
print "DONE"
# Define a function that is called every time a keyboard button is pressed
def mykeyboard(key):
# Calls the function SaveData and hands it the current time and key
if key==' ':
SaveData()
# Defines a callback for keyboard events
viz.callback(viz.KEYBOARD_EVENT, mykeyboard)
import csv
SampleRate = 1.0 # samples per msec
def getSequence(name = 'inputdata.csv', language = 'English'):
mesg = viz.input('Enter the filename:')
name = str(mesg)
sequence = []
sequenceFile = open(name)
reader = csv.reader(sequenceFile)
for line in reader:
# adjust the resolution of the input based on sample rate
# We have to basically multiply each element in the input sequence by
# the SampleRate (defined as samples per msec and assuming all input is in msec)
# and use that integer result
sequence.append(int(SampleRate*float(line[0])))
return sequence
if __name__ == "__main__":
#testing code
sequence = getSequence()
for item in sequence:
print item
csv file:
1
2
3
8
9
Old 03-21-2008, 03:21 PM
You need to prepend the publish EXE path to the filename, otherwise the file will be saved to the current directory, which is in a temp folder. Here is some code to get the full path to a file in a published EXE:
def getPublishedPath(filename):
	publishPath = viz.getOption('viz.publish.path','')
	if publishPath:
		return '/'.join([publishPath,filename])
	return filename
file = open(getPublishedPath('response.txt'), 'w')
text output jaclyn.bill Vizard 2 10-24-2007 06:37 AM
Error when playing wav files...? vjonshih Vizard 1 05-23-2005 12:21 PM
loading large wav files in vizard tommahhh Vizard 1 05-16-2005 03:23 PM
3d Text with Transparent Borders vjosh Vizard 3 12-01-2004 10:50 AM
Including Files that Include Other Files vjosh Vizard 1 09-21-2004 04:44 PM
