Old 03-09-2011, 10:30 AM
Kaminski Kaminski is offline
Translate view from sensor position to lens position?
Has anybody made a function to translate the viewpoint from the sensor position to the lens position on their hmd? I'm having a little trouble figuring out which method to use (preTrans, postTrans, or setOffset).
Old 03-09-2011, 10:40 AM
If your sensor contains both position and rotation data, then you need to apply a preTrans operator on the link to apply the offset between the physical sensor and actual eye position.
Example:
view_link = viz.link(sensor,viz.MainView)
# Physical sensor is 0.05 m above and 0.02 m behind actual eye position
view_link.preTrans([0.0,-0.05,0.02])
Old 03-09-2011, 11:08 AM
Yes sensor has both position and orientation (IS-900).
I am trying to run this on update so that I can use the euler information to determine which directions to apply the translation. When I use preTrans the view flies off in one direction.
I have tried subtracting the translation values from the preceding preTrans call, but that results in an accumulative translation error over time. I have also tried reseting each time before applying the preTrans. Both are commented out below. Thanks.
import viztask
import math
viz.go(viz.HMD | viz.STEREO)
isense = viz.add('intersense.dle')
track = isense.addTracker()
main = viz.link(track,viz.MainView)
def mainLoop():
	yield viztask.waitKeyDown(' ')
	#Do Stuff
xOffOld=0.0
zOffOld=0.0
hmdLength = .29
def setViewTrackCorrection():
	global xOffOld,zOffOld
	#main.reset(viz.HEAD_POS)
	eul = main.getEuler()
	xOff = hmdLength*math.sin(math.radians(eul[0]))
	zOff = hmdLength*math.cos(math.radians(eul[0]))
	#main.postTrans([-xOffOld+xOff,0,-zOffOld+zOff])
	main.preTrans([xOff,0,zOff])
	xOffOld = xOff
	zOffOld = zOff
vizact.onupdate(1,setViewTrackCorrection)
viztask.schedule(mainLoop())
Old 03-09-2011, 11:32 AM
My mistake, I didn't realize preTrans was applied before rotation. Thanks for the help.
Old 03-09-2011, 11:36 AM
You should not call preTrans on every update. You only need to call it once when you initially setup the link.
import viztask
main.preTrans([xoff,yoff,zoff])
def mainLoop():
	#Do Stuff
display the position and euler coords of the main view Josh Vizard 1 03-22-2010 11:48 AM
View nlfrnassimi Vizard 0 03-17-2009 03:01 AM
View nlfrnassimi Vizard 4 03-12-2009 06:25 AM
default start position erchrastil Vizard 2 06-23-2008 09:15 AM
problem with stereo mode shivanangel Vizard 3 10-17-2006 10:58 AM
