Old 09-24-2020, 11:25 AM
nom nom nom nom is offline
Sound freezes Vizard simulation
After reinstalling my Windows, suddenly the sound play in Vizard causes a quick freezing of the simulation. This occurred in both VR and non-VR settings as well as my own code and the example code (I used the below code from the documentation). I use Vizard 5.
I checked the framerate. The framerate is at 75 Hz, then when the sound is played, it suddenly drops to about 20 Hz for a second then recovers back to 75 Hz. This interference from the sound only occurs in Vizard and not other programs, so I assume this is something related to Vizard.
viz.setMultiSample(4)
viz.fov(60)
viz.clearcolor(viz.SKYBLUE)
#add localized sound
duck = viz.addAvatar( 'duck.cfg' )
duck.setEuler([180,0,0])
duckMove = vizact.sequence( [vizact.moveTo([0,1,22],speed=2), vizact.moveTo([0,1,0],speed=2)], viz.FOREVER)
duck.addAction(duckMove)
quack = duck.playsound( 'quack.wav', viz.STOP )
vizact.onkeydown( 'q', quack.play, viz.LOOP )
I wish I could attach a video, but I guess I can't. Does anyone know why this occurs?
Old 10-05-2020, 03:56 PM
kennethkarthik kennethkarthik is offline
Moderator
Hi nom nom,
I'm not able to recreate this issue in Vizard 6. Let me try it out with Vizard 5 and let you know if there's a fix. Until then, feel free to use the Vizard 6 free download to test out your scripts without the frame drops.
sound freezing
How to pause the Vizard simulation? 4711 Vizard 4 03-18-2010 04:45 PM
3D sound in Vizard whj Vizard 2 07-28-2009 12:42 PM
3D sound in vizard virtmeg Vizard 1 01-10-2005 09:06 AM
