Old 06-10-2011, 12:10 AM
chris_user chris_user is offline
easeIn for a spin?
hope I can make my question clear to you.
I want a certain part to start spinning until the user stops it, so far it worked with the spin command. But it looks a little bit weird if it simply starts and stops without increasing speed. My problem is I can't create this effect with the spinTo command and use the embedded interpolation methods.
Tips to get a solution are welcome.
Chris
Old 06-10-2011, 02:55 PM
Can you post some example code that does not work for you?
The following uses vizact.easeIn to start the spin slowly:
gallery = viz.addChild('gallery.ive')
ball = viz.addChild('ball.wrl',pos=[0,1.8,3])
spin = vizact.spinTo(euler=[180,0,0],speed=45,interpolate=vizact.easeIn)
vizact.onkeydown(' ',ball.addAction,spin)
Old 06-14-2011, 07:04 AM
Hi Jeff,
my problem is that the spinTo command just catches the shortest way so far, but I need a steady rotation going on until you hit a key and it stops. Sometihng like a running wheel. It starts slowly and increases the rotationspeed till it hits his running speed. Hope I could make it a little bit more clear to you.
Chris
Spin around one point Ellen Vizard 3 07-01-2010 11:14 PM
Spin Actions and rotations Vinicius Lima Vizard 1 10-22-2007 11:49 AM
spin around axis object kazo11 Vizard 2 04-19-2007 09:48 AM
Spin Move oscar Vizard 2 12-03-2004 05:52 AM
