Old 05-04-2010, 10:43 AM
shahramy shahramy is offline
Unhappy how to change shadow direction?
i used Shadow module to create shadow but I cant change the direction of shadow in the other hand the point in which the imaginary light source exists. i have used this code.
SHADOW_RES = 2048
#Postion of shadow projector
SHADOW_POS = [-30.800,5.000,50 ]
SHADOW_AREA = [150,150]
#Create shadow projector
shadow = Shadow.ShadowProjector(size=SHADOW_RES,pos=SHADOW_ POS,area=SHADOW_AREA)
#Add avatar as a shadow caster
shadow.addCaster(obj1)
shadow.addCaster(obj2)
#Add ground as shadow receiver
shadow.addReceiver(sh)
with this shadow_pos the shadow will create exact under the two object which have many distance from each other!!!
Old 05-05-2010, 12:22 PM
The following example shows how to set the position and orientation of the shadow projector. It moves in a circle around the avatar and turns so that it is always pointed at the avatar.
#Add ground model
#Add avatar
avatar = viz.add('vcc_female.cfg',euler=(180,0,0))
avatar.state(5)
#Shadow resolution (power of two)
#Higher values mean sharper shadows, but take more texture memory
SHADOW_RES = 256
SHADOW_POS = [0,0,0]
#Controls size of orthographic shadow projector
#Large values mean larger area is covered, but resolution will be diluted
SHADOW_AREA = [5,5]
import Shadow
shadow = Shadow.ShadowProjector(size=SHADOW_RES,pos=SHADOW_POS,area=SHADOW_AREA)
shadow.addCaster(avatar)
shadow.addReceiver(ground)
import math
SPEED = 0.5
def moveProjector():
    t = viz.tick() * SPEED
    # Move projector in a circle
    newX = -math.cos(t) * 2
    newZ = math.sin(t) * 2
    shadow.setPosition([newX, 2, newZ])
    shadow.setEuler([t/math.pi * 180,40,0])
vizact.ontimer(0,moveProjector)
import vizcam
viz.cam.setHandler(vizcam.PivotNavigate(center=[0,1.5,0],distance=7))
Old 05-05-2010, 09:37 PM
thanks man. that is great. vizard is the best
setEuler method of Shadow module omidbrb Vizard 1 02-22-2010 09:35 AM
Change Viewpoint in different scenes lilio Vizard 1 08-28-2009 02:56 PM
Change model alpha and memory leak hosier Vizard 2 06-25-2009 10:55 AM
Draw Vector in viewpoint lookat direction Chrissy2009 Vizard 2 05-30-2009 12:50 AM
