I think you have to use the method setVertex for the line that you created
this code is a example of a line that moves in X Code:
import viz viz.go() viz.startlayer(viz.LINE_STRIP) viz.vertexcolor(0, 0.6, 0) #This is vertex 0 viz.vertex([0,0,0]) #This is vertex 1 viz.vertex([1,1,0]) line = viz.endlayer() x=0 def moveLine(): global x line.setVertex(0,[0+x,0,0])#setVertex(vertex id,[x,y,z]) line.setVertex(1,[1+x,1,0]) x = x+1 vizact.ontimer(1,moveLine) |
| Thread Tools | |
| how to invoke command line question | billjarrold | Vizard | 2 | 01-11-2010 08:51 AM |
| Draw line and rotate it | Chrissy2009 | Vizard | 5 | 09-07-2009 01:10 AM |
| Draw line with a triangle at the end | Chrissy2009 | Vizard | 9 | 08-24-2009 11:12 AM |
| Draw Line between Points | Chrissy2009 | Vizard | 2 | 05-13-2009 04:42 AM |
| Draw Line between Points selected by mouse | Johannes | Vizard | 7 | 01-07-2005 02:50 PM |
