Old 03-25-2010, 10:25 AM
lionfish lionfish is offline
Changing alpha in already textured objects
A little problem I solved, that others might have. I was trying to set the alpha of an object:
cloudTexture = viz.addTexture('pink4.png')
cloud = viz.addTexQuad()
cloud.setPosition(0,0,0)
cloud.texture(cloudTexture)
cloud.alpha(0.5)
This doesn't seem possible. The solution (for me) was to use an image that doesn't have alpha information, i.e. convert pink4.png to pink4.jpg. It then works
Mike.
Old 03-25-2010, 10:52 AM
That shouldn't be the case. I just tried your code here with an alpha texture and it worked fine. Can you post a sample script with the image you are using that reproduces the issue?
Collision with objects having alpha channel applied to omidbrb Vizard 1 07-20-2009 09:56 AM
trouble changing subnode (child node) color, alpha, etc. michaelrepucci Vizard 7 01-14-2009 08:38 PM
fixing alpha textured objects joeymax Vizard 5 05-09-2008 11:31 PM
Changing the Color of On-the-Fly Objects vjosh Vizard 1 01-04-2005 11:48 PM
