Old 03-11-2010, 01:38 AM
tsgk tsgk is offline
Shifted screen
Hi all,
In my setting the screen is shifted (i.e. the middle of the screen is not at the eyeheight of the participants).
Is there a way of communicating this to Vizard so it renders the scene appropriately?
I've tried searching for it in the Vizard help files but without any luck!
Thanks in advance!
Old 03-11-2010, 09:11 AM
Can you describe your hardware setup more? Are you using tracking?
Old 03-12-2010, 01:48 AM
I am not sure what you mean by using tracking. I am projecting the scene using a back projecting screen (2m by 1.5) which is 43.5cm above the ground. So, when people's eye-height is set to 1.05m that does not correspond to the centre of the display, but a bit lower than that, so the horizon is wrong.
I am recording eye-movements as well as the position within the scene. Is that any help?
Thanks!
Old 03-12-2010, 09:47 AM
Have you tried adjusting the Y position of the main viewpoint?
Old 03-15-2010, 03:33 AM
When I change the Y position in viz.MainView only the eyeheight is affected. Do you mean change the pitch value in .setEuler?
screen capture from all cluster computers? dtidrow Vizard 1 09-16-2009 10:25 AM
split screen honey006 Vizard 3 05-21-2009 09:57 AM
screen image erchrastil Vizard 8 06-27-2008 11:45 AM
position of html-file on screen active_world Vizard 1 05-16-2008 07:24 PM
accessing screen buffer hotspur1 Vizard 3 08-22-2003 03:31 PM
