Old 03-06-2010, 02:02 AM
atamasan atamasan is offline
Stereoscopic view question
Hello.
I have a question. When I use HMD, I know I must use viz.go(viz.HMD).
I can see 3D objects through the HMD. And I know the "ipd" should be set because the value is different each person. So I changed the value to see the effect of ipd. I changed like this:
viz.ipd(.2)
But nothing changed. So, after that I tried again, like this.
viz.go(viz.STEREO|viz.HMD)
viz.ipd(.2)
This time(when I use viz.go(viz.STEREO|viz.HMD)), objects were rendered only right side of the window. What are the reasons for this? Please let me know.
PS I am using emagin's z800.
Thank you .
Old 03-08-2010, 11:07 AM
The viz.STEREO flag renders left and right eyes side by side. This is used for a device that works with passive stereo.
Try using the viz.QUAD_BUFFER flag if your graphics card supports quad buffered stereo.
Old 03-09-2010, 10:13 PM
Thank you very much for your advice.
O.K. I'll try using "viz.QUAD_BUFFER"
Thank you again.
View point question atamasan Vizard 7 01-26-2010 05:56 PM
View nlfrnassimi Vizard 0 03-17-2009 03:01 AM
View nlfrnassimi Vizard 4 03-12-2009 06:25 AM
problem with stereo mode shivanangel Vizard 3 10-17-2006 10:58 AM
Stereoscopic Vizard Question mikestatic Vizard 7 03-20-2006 03:36 PM
