Old 12-10-2009, 05:40 PM
EnvisMJ EnvisMJ is offline
How do I run a destructor before the end of the program?
I am writing a program that is basically just a bunch of critters running around.
I can create them fine...but how do I run the destructor on them when they die without waiting till the end of the program?
Old 12-10-2009, 09:19 PM
You can use the <node3D>.remove() command to permanently remove the object from the scene.
Old 12-11-2009, 07:34 AM
2 questions about that,
Does the .remove() actually run the destructor also? Does it free up it's resources, etc?
Also, it throws a '...does not have .remove() function' error when I try to run it on my own class object. Do I need to do something special to include .remove()?
Old 12-14-2009, 06:17 PM
Yes, it will free up resources used.
This method will work on Vizard's node3D objects.
changing the gain of a joystick during a program Saz Vizard 4 06-25-2009 04:49 AM
Is it possible to save a vizard program as (movie) a media file? ghazanfar Vizard 5 05-07-2007 11:03 AM
Get position data in an own little program Researcher Precision Position Tracker (PPT) 2 02-01-2006 03:55 AM
Multiple Stages in one Program Amit Vizard 7 11-11-2005 11:20 AM
Loading .3ds-Files without interrupting Program flow Stefan Vizard 10 06-08-2005 05:44 PM
