Old 10-07-2009, 11:35 AM
kay kay is offline
ERROR: Failed to initialize python
I get the following error message, when trying to run any script:
'import site' failed; use -v for traceback
File "<string>", line 1, in ?
File "C:\PYTHON26\LIB\os.py", line 757
bs = b""
SyntaxError: invalid syntax
File "C:\Programme\WorldViz\Vizard30/python\viz.py", line 10, in ?
import os
bs = b""
** ERROR: Failed to initialize python
Apparently Vizard tries to use the Python 2.6 installation in stead of it's own installation of Python 2.4!?
Do I need to change the Python search path for Vizard 3.0?
How could this be changed?
Old 10-07-2009, 11:51 AM
This sounds like you have either the PYTHONPATH or PYTHONHOME environment variables pointing to your Python 2.6 installation. I would recommend removing these environment variables. They are generally not needed and will cause problems if you have multiple Python versions installed on your machine.
IE cannot display form response page from python server Gladsomebeast Vizard 2 12-01-2008 09:12 PM
python 2.4 instead of 2.3? perselletje Vizard 7 03-14-2006 11:06 AM
Extending Python With C++ Vygreif Vizard 2 01-18-2006 09:21 AM
Use Vizard 2.5 with Python 2.4.1 / IDLE 1.1.1 Gilliard Vizard 4 08-04-2005 11:49 PM
