Old 09-24-2009, 01:26 PM
JimC JimC is offline
Question Access to VizCustomNodeObj::data
Is the float* data member of VizCustomNodeObj read-only from the Python side? I see a get() method in the docs that presumably returns it to the Python script, but no corresponding set() method...
Old 09-24-2009, 01:36 PM
Yes, the Python script only has read access to the float array. However, you can send commands to the plugin using the node.command() method.
Old 09-24-2009, 01:44 PM
OK, thanks. So if my plugin has e.g. 8 parameters I would set them using two calls to command() with different values for mesg...
Access to Geometry Data in a c++ plugin for vizard. xabbu Plug-in development 1 01-16-2009 04:14 PM
How to access scene information in a C++ modifier m7ossny Plug-in development 1 03-23-2007 12:02 PM
Direct access to phantom omni data vsully Vizard 1 03-14-2006 10:44 AM
dynamic access of avatar location valhalla Vizard 1 09-13-2004 09:28 PM
Getting access to the eyes of CFG avatars bailenson Vizard 1 06-18-2004 05:55 PM
